  1. Penfold
    Penfold Newbie
    Hello,
    My 1986 trabi has developed a new running pattern which I’m trying to source the cause of.
    When being driven it:
    - runs fine when accelerating
    - runs fine when idling
    - kangaroos under gentle constant throttle
    It was fine until recent runs. Fuel is only a few weeks old and the exhaust is on tight. First thouht was the loose flange connection I found, which addressed an issue I had with idling.
    Any views on where to look first? I’ve got a set of seals for the carb and was debating stripping, cleaning and rebuilding it as the first step. If it’s unlikely to be the cause then I’ll leave it alone!
    If I do need to take it off, is there an easy way to get to the flange fasteners. On quick inspection it looks a pain!
    Thanks,
    Penfold
    It sounds like a carb issue to get to the flange bolts it's easier if you loosen the alternator bolts and drop the belt off so you can swing the alternator lower out of the way it's still a bit fiddly getting the bolt nearest the gearbox but not to bad
  3. Penfold
    Penfold Newbie
    Thanks Kev.
  4. Steve
    Both my Trabbis lurch a bit under gentle acceleration or constant speed especially in 2nd and 3rd gear. Not so much in 4th gear. I put this down to a natural 2 stroke behaviour as you don't get a smooth firing pattern, just like when it's idling. Or it could be your plugs are fouled up and need changing.
  5. kev the builder
    As Steve said two strokes hunt on light throttle but shouldn't kangaroo but it can be difficult to determine what's normal if you've never experiaced a trabi before
