1. kev the builder
    Your spot on there with the mot standards it's a pity more people don't pay at tension to them I've come across some well dodgey repairs the worst was sills made from cardboard and filler and one made from rags and filler which probably took longer to make than it would to replace with new steel
    How to fix sills easy:
    1: fill in expanding pu foam.
    2: cut off anything that comes out the rust holes.
    3: spray sealer on it
    Done. :D
    Seen that a few times, and its not fun to repair proberby when MOT guy finds it with his pointy hammer. :)
  3. Andrew
    Andrew Most Powerful Leader Moderator Forum Donor
    Speaking of Rust, I took to my Kombi with a light pass with the wire wheel to figure out how much metal was actually left in the roof edging, turns out, even less then I had thought.
    I am not sure if I can save the roofing at all, as finding actual metal that can be welded on to is well.... difficult, and I will be there for 6 months worth of weekends just trying to patch one side, and this is based just on "better" side of the car.
    Haven't managed to do much proper investigation into the driver's side as the wall is in the way.
    Still a bit of a toss up at the moment, as what to do with it... I would very much like to try and save in one way or another, but my options are getting rather thin at the moment..
    Think I also figured out why the drivetrain was quite shaky on my last leg into sydney.
    Also figured out I was wrong about the Kombi having CV joints, when I dumping a lot of grease into the joints in Adelaide I thought I felt the cv gears, turns out I was wrong...
  4. Steve
    Finally got both top swivel joint bushes reamed out ready for re-assembly. (Well only one actually, as the one fork which I was able to use again pressed in with hand pressure and a little grease. ) The other was a brand new one and needed a little coaxing from the reamer. So I see there should be 0.1 mm end play in the shaft. How the hell do you measure that? Then I have to get the drive shafts back in the hubs. One shaft came out with the inner wheel bearing attached, the other side inner bearing stayed in the hub. Gotta decide the best way how to get those back in place.
  5. mbeamish
    Basically you shim it until there is a fraction of vertical movement you want to be able to feel it but not see it . But not so tight the nut binds ,must turn freely
  6. Steve
    trabbipix.jpg Received and fitted my little funnels from China to correct the design flaw which contributed/caused the corrosion on my Trabbi underneath the battery area and corresponding area on the other side of the engine compartment. I was getting puddles of rain forming when parked on an incline due to bad drainage of the gutter around the bonnet edges. I just glued them with 5 minute epoxy under the existing holes for the rubber grommets which cushion the bonnet. Just cut off the bit of rubber that goes through the hole and stick it down nearby as on the pictures. If the epoxy doesn't make a waterproof seal then run some silicone sealant around the edges. Just attach a long enough plastic tube to run off the rainwater out of the affected area. View attachment 4905 View attachment 4905 trabbipix2.jpg
    What's wrong with the axle? What am I not seeing?
    On mine there is some play on the wheel end but the hinge pins are not worn. I took a video but has since deleted it. I can't stand to hear my voice after recording!
    I was trying to track down this thumping sound which seems to get worse as the temperature get's colder but never could track it down.
    I found no play in the wheel bearings. Could be the tires. Could be out of round or high spots in the drums.
    I see what your talking about now. Mine had not rotted out in this location but since this seems to be vulnerable, I'll give mine a coating of the Eastwood's Rust encapsulator to prevent any potential corrosion. That way if water puddles, it won't penetrate the metal.
  9. Andrew
    The pin at the end of the drive shaft, it is nowhere near centred and it is supposed to be, otherwise you are going to end up with a major wobble in the half shaft....
    Edit:
    I also tried to remove the last rear window out of the kombi tonight, and there was only a small gap between the car and the wall for me to position myself, anyway long story short, I pulled the last of the rubber out, and the immediately dropped the window all over the ground :( Luckily since I am going to be cutting the roof off, it doesn't really matter... other than I had to spend 30mins cleaning glass up...
  10. mbeamish
    Poor kombi ,on death row desperately hoping you will buy the kit and save it
  11. Steve
    Fitted this little £15 gadget today because I am not really happy with the standard fuel tap setup. I have replaced the cork washer with 4 holes in it located in the fuel tap, with a factory rubber version, but tightening the 2 screws which hold the assembly makes it hard to turn the tap on and off with the bit of wire rod from the under dashboard control. If I unscrew the 2 screws sufficiently to make it usable, then petrol leaks from it. So I decided to bypass this system, turn the tank fuel tap permanently on and have an inline solenoid operated fuel tap which opens on ignition turn on. I just wired the plus side to one of the ignition coils, and the negative to the body (fixing screws). trabipix3.jpg
  12. kev the builder
    I fubd if you smear petrolium jelly(vaseline)on the rubber seal it turns easier its a bit late now for you now tho
  13. Steve
    Well I had a lovely time re-assembling the front axles today, or should I say axle. I only had time to do one because I struggled with deciding how to go about it. The main problem was getting the outer drive shaft through the wheel bearings. I thought about various ways to do it, but finished up splitting the drive shaft at the universal joint by taking out one of the pins. Then I tried to tap the outer shaft through the bearings, but it was pretty tight so I put the shaft in the freezer for an hour. That did the trick, and it tapped in quite easily. I had left the drive shafts still attached at the gearbox, and the left hand one(driver's side) had come out of its housing and the rectangles on the shaft end had turned and wouldn't re-engage, hidden by the gaiter. So I ended up having to take off the inner gaiter to see how the shaft end located. Interesting the way it is designed. I was expecting to lose gearbox oil when I took of the inner gaiter, but saw that it is a sealed drive cup with grease to lubricate the inner shaft end. Anyway, I cleaned up the shaft and gaiters and fiddled with the tiny circlip which holds the pin at the universal joint. Not easy with big fat fingers and crappy circlip pliers. Off to Newcastle tomorrow, but back Sunday to do the other side.
    And, I'm hoping if all goes well in the next few days to take Hildegard for her MoT test!!! Four and a half months of endeavour outside in winter! I hope it's all worth it.
    Ron likes this.
  14. turbofiat124
    That pin your talking about on the axle should center itself when you slide the hinge pieces on it and insert it into the gearbox. If that makes any sense. Unless there is something else I'm not seeing. Is the pin and simply worn out?
    I got rid of that petcock valve ages ago and went with the solenoid valve. I never could figure out which position was what! I'd either forgot to turn it off and find a puddle of fuel under my car in the morning or forget to turn it on and make it 1 mile down the road and the engine dies!
  15. kev the builder
    The manual fuel tap can be a bit of a pain when you forget to turn it off and on but it makes a basic anti theft device,i turn it off as i pull up in front of my drive and then drive down it so it drops the level in the carb and helps stop it dripping when parked
  16. mbeamish
    Yes there have been quite a few posts over the years where stolen cars have been recovered after they ran out of fuel and the thieves abandoned them
  17. Andrew
    @turbofiat124 I don't think so, I am pretty sure that pin is pressed in, I tried recentering it but it wouldn't budge by hand or via persuasion with a rubber mallet..
    Still waiting to hear back from the local certifier, and I can't really do anything till I get his go ahead (cutting chassis wise) or from the German guy who sells the kubelwagen kits...
    But took the rear right panel off to make sure there wasn't hidden rust around the edging, a prelim exam after taking the panel off looks good, It would appear that all the wax that was put in the cavity had all melted to the bottom and created what appears to be a protected layer down there, but its also appears to be the location where half the roof migrated to based on the amount of rust particles I've discovered...
  18. Steve
    I think to rely on the fuel tap as an anti-theft device is to say the least, a bit optimistic. Any opportunist thief would be stupid to try and take a Trabant, and it wouldn't actually stop them driving until the fuel starved, by which time they could have crashed or damaged your pride and joy. Trabants are slow, easily recognizable because it's different, a gear change pattern like no other, etc. Unless the thief particularly wants a Trabant in which case he/she would know about the fuel tap, a visible deterrent such as a steering wheel lock bar or road wheel clamp is far better.
  19. mbeamish
    Well on here vdubbin got his car back with minor damage when the thief ran out of petrol a few weeks ago and i can remember at least half dozen similar cases on here and yahoo group over the years
  20. turbofiat124
    Like I mentioned, I'm surprised someone could even figure out how to shift a Trabant unless they had prior knowledge.
    A better immobilizer would be to install a toggle switch up under the dash that goes from the ignition switch to the coil. Then the car wouldn't even start.
