  1. Stuart-C
    Stuart-C Puttering Along
    The cover that protects the 3 wires coming from the ebza into the crank? Mine fell off on the motorway and the car died as it took out the middle green wire. I cant seem to find it on LDM or Trabantwelt.
  3. Stuart-C
    Yes it was like that but mine had a cut out for the electronic ignition wires to go up through. And It was held on by one or perhaps two screws. Maybe this was wrong and why it fell off?
    What I posted is original for a trabant. Its held on by a large 'spring clip' . The wires normally go into the ignition housing at the side through a grommet. Sounds like yours has been bodged perhaps because spring clip broke off.
  5. kev the builder
    Hi it's called the points cover I think mbeamish is right about yours being bodged in the past,I think ldm sell the cover
  7. TheHun
    Yep, should not have any bolts holding it, believe the wire should come out through a small cutout on the side of the box instead, that is if you have oem parts for the ignition insight, can you take a picture of the box without the cover...
  8. Stuart-C
    Ok thanks for that. Conundrum solved.
  9. Zausel
    Zausel Loyal Comrade
    Anyone know how to replace the spring clip? My new engine is without and would like to replace it. It's sort of a rivet, right? Drill it out, replace and drive a sheet metal screw in at the pivot?
  10. kev the builder
    If you twist it as you pull it it should come out,that's if yours isn't snapped off leaving just the piece in the housing which you will have to drill out carefully as the clips harder than the housing
